I intend to build a small system around one voice ( plasma voice from Gamechange Audio) using a 48 hp pod! ( i might consider expand ,if a specific setup will bring more on the table ) again, i will only use plasma voice as osc/voice!
I want to have rhythm with this voice...phrases that can be rather melodic or percussive, but not too advanced deep modulations! System needs an output module !
I am using external effect processors!
Would you go tactile/ spontaneous trigs/gates or would you use an actual small sequencer/arpeggiator? I suppose a sequencer/arpeggiator would fit better!
What envelope generator would you use?
Would appreciate your vision on this system!
