The Arp Of Darkness is an arpeggiator with a unique twist: It's designed to create dynamic and evolving note sequences by utilizing a buffer approach similar to a Turing Machine or Shift Register. Unlike traditional arpeggiators, which typically play chords as individual notes in a predefined pattern, this module allows you to enter notes sequentially into a buffer of variable length, (from 3 up to 16 notes) and play it back using 5 playback modes more commonly found in arpeggiators. (Forward, Backward, Exclusive Pingpong, Inclusive Pingpong, and Random).
This module is a part of the emerging Nocturne Alchemy Platform - a flexible eurorack module series that shares the same robust Arduino-based hardware, allowing one to effortlessly swap functionalities through our intuitive web loader. By purchasing one module, you gain access to a full range of freely available firmwares, including our current creations, Slight of Hand and Arp Of Darkness, as well as others planned for future release! It's like getting multiple modules for the price of just one!
Specs
1U (Intellijel format) 26HP Module
40mm skiff-friendly depth
Current Draw: 40 mA +12V, 0 mA -12V, 0 mA 5V
Features
4 octaves of control from C0 to C4
6 note buffer lengths (3, 4, 5, 6, 8, 16)
5 playback modes (Forward, Backward, Exclu Pingpong, Inclu Pingpong, and Random)
Clock input and CV out calibrated to 1V/0
Calibration mode with tuning for each note across 4 octaves (Comes pre-calibrated)
