Advice? Feedback?
I've done patching in software programs and some semi-modular with a Moog DFAM and Werkstatt, but that's about it. I'm familiar enough to find my way around with a little elbow grease and googling, have learned a bit about how CVs work vs audio, gates and triggers, etc. -- but def. still amateur enough to expect some weird hiccups and things I didn't consider.
https://cdn.modulargrid.net/img/racks/modulargrid_1532287.jpg
I figure I'll work mostly with the Doepfer modules initially and probably the 2hps, as I get a better feel for how to patch everything effectively, along with the the 3 VCA/mixing and attenuator type units. Once I feel confident with my understanding of those, I'll start to pepper in the fancy lads one at a time, like the MS Ensemble VCO, Mind Phaser, Rampage, and Typhoon.
Anything you feel is missing or will be problematic or that I might prioritize? My goal, long term, is to explore pretty experimental meandering noise-meets-IDM type stuff. Like Autechre but more fun, say. Structured, playful, a little dramatic. Old material can be found in my blog at https://www.edwardewald.com/blog/
Thanks for taking a peek. Components broken out below. I'd love some on board sequencing and logic, that will probably come in the coming months, but I do have a DFAM, Werkstatt, an EM Clockworks, and a Rucci 16 step sequencer to work with externally, not to mention my PC, and an old Yamaha keyboard that has a MIDI sequencer, so I figured that'd be plenty to start in terms of just getting some things happening. I'd also like a dedicated white/colored noise source, but I figure I can snatch one pretty cheap on Reverb at some point. Beyond that I'll definitely be gravitating towards things like Pachinko and Chance (Qu-Bit), things that facilitate randomness and chaos, but in a controllable way.
If the Doepfer VCO and the MS VCO prove repetitive -- especially with the Mini Shimmery and Mind Phaser in there -- I might sell off one or two of those. I might also pawn off the BBD delay if the Typhoon covers everything for me, though I'm not amiss to the idea of playing with multiple delays, so... have to see.....
Anyway, all thoughts welcome thanks for looking/reading.
Mazzatron Testy     Mazzatron Testy
Patch Cable Tester  1   2 HP    21 mm   1 mA    0 mA    0 mA
Mutable instruments Ears        Mutable instruments Ears
Contact Microphone  1   4 HP    25 mm   5 mA    5 mA    0 mA
Doepfer A-111-2v        Doepfer A-111-2v
High end VCO (Vintage edition)  1   14 HP   55 mm   70 mA   50 mA   ?
4ms Company Ensemble Oscillator (Black Panel)       4ms Company Ensemble Oscillator (Black Panel)
Black panel for the Ensemble Oscillator     1   16 HP   25 mm   114 mA      45 mA   0 mA
2hp Brst (Black Panel)      2hp Brst (Black Panel)
Voltage Controlled Burst Generator and Trigger Delay    1   2 HP    42 mm   26 mA   7 mA    0 mA
Doepfer A-121-2v        Doepfer A-121-2v
12dB Multimode Filter (Vintage edition)     1   8 HP    50 mm   40 mA   40 mA   0 mA
Doepfer A-141-2v        Doepfer A-141-2v
Vintage edition panel version of the A-141-2 ADSR/LFO   1   14 HP   70 mm   40 mA   30 mA   ?
Doepfer A-188-1v        Doepfer A-188-1v
Bucket Brigade Delay Module (Vintage edition)   1   14 HP   60 mm   80 mA   50 mA   0 mA
ADDAC System ADDAC216       ADDAC System ADDAC216
Sum & Difference    1   8 HP    ?   ?   ?   ?
Blue Lantern Modules Mini Shimmery MK2      Blue Lantern Modules Mini Shimmery MK2
Percussive Metallic Generator   2   10 HP   64 mm   ?   ?   ?
Hexinverter Électronique Mindphaser     Hexinverter Électronique Mindphaser
next-gen analog complex oscillator || thru-zero phase modulation in the analog realm    2   30 HP   24 mm   110 mA      100 mA      0 mA
2hp S+H (Black Panel)       2hp S+H (Black Panel)
Dual Analog Sample and Hold     2   2 HP    42 mm   5 mA    5 mA    ?
Befaco Rampage      Befaco Rampage
Dual Sergesque Slope Generator with Logical Crossfading     2   18 HP   30 mm   110 mA      90 mA   0 mA
CalSynth Typhoon - Black aluminum       CalSynth Typhoon - Black aluminum
Expanded Clouds with sliders    2   16 HP   25 mm   160 mA      35 mA   0 mA
Doepfer A-135-2v        Doepfer A-135-2v
Quad VCA / VC Mixer (Vintage Edition)   2   8 HP    45 mm   40 mA   40 mA   0 mA
Doepfer A-138sV     Doepfer A-138sV
Mini Stereo Mixer   3   8 HP    30 mm   10 mA   10 mA   0 mA
