Hey everyone!
I'm in the process of building out my first rack and I'm hoping for criticism and guidance. I'm pretty new to this and having done a ton of reading on this forum and hours of listening to Youtube demos, I got overwhelmed and decided to ask for your help.
I started out with Befaco Oneiroi and Mother 32, fell in love with the sound and the possibilities, and I want to build a rack instrument with dirty industrial synths, dark ambient drones and irregular noise rhythms.
Musical inspirations: Skinny Puppy, Meshuggah, Moderat, Brian Eno, Nine Inch Nails, MZ.412, Burial, Autechre, Front 242.
I'm not planning to perform live, but I want hands-on controls and as little menu diving as possible.
Here's the breakdown:
Misc
  • Case: planning to go for TipTop Mantis
  • I have the Oxi One, which will be doing clock, sequencing and lots of modulation.
  • Audio mixing is done into RME Fireface UCX II and eventually recorded into Ableton (but I don't want to have the computer hooked up to the system on a daily basis)
Voices
  1. Mother 32 - already have it, will pull it out if I need space for more modules. Love the sound on this thing.
  2. Coral - it's a bit complicated but I figured it's a ton of functionality per HP + integrates well with Oxi One.
  3. Oneiroi - already have it, absolutely love it.
  4. (not Euro) Digitakt 2 - already have it, for drums and samples.
Modulation
  1. Oxi One - serves clock, sequencing, envelopes, LFOs, triggers, pitch etc.
  2. Zadar - envelope generation, mostly for Oneiroi. I love the visual feedback from the screen.
  3. Polimaths - I don't fully understand it…but it seems like it can give me tons of CV modulation to create unpredictability and polyrhythmic grooves.
Effects
  1. Ruina Versio - distortion, noise. I love how it sounds, hands-on control looks fun + super flexible, as I can flash other modules onto it.
  2. Mimeophon - delay, reverb, looper. I'm looking for an excellent-sounding delay/reverb that can do weird things if needed, and after hearing a million demos, this seems to be it. It sounds almost as good as Starlab to my ears, and its capability to do weird sounds very fun and musical to me.
Utilities
  1. Oxi Pipe - 8x CV and 8x gates from Oxi One.
  2. FH-2 - MIDI from Oxi One for even more modulation. Makes me wonder if I need Zadar?
  3. Warna II - looks very cool and useful, but I'm not sure if I need it, since there is a simple mult in Mother 32 and Polimaths is so powerful.
  4. Nano ALT - this seems to be the most feature per HP quad VCA I could find.
What do you think? What am I missing? Thanks for looking!!
You look to be on the right track.
Good choice of first case. I'd suggest removing the Mother into it's own case to create more room but you can come to that point organically as your system grows.
Perhaps look into additional utilites such as switches (quad sequential, et al.).
LFOs also seem underrepresented unless you want OXI One handling all of those.
Maybe a filter?
You may also eventually find yourself wanting additional vcas.
You're probably best off working with the above for a while and seeing what limitations you're bumping up against, and adding capabilities based on that.
Best of luck!!
Edit: I just realized you had polimaths vs. normal maths. Unless you're planning on expanding with Make Noise's New Universal Skiff System, you may be better off running a regular ol' maths? I'm not very familiar with the NUSS, so don't quote me on that, though.
― Friedrich Nietzsche
That's the plan!
Literally never heard of those. Thanks, I'm off to read about them!
Yes, that's the plan for now - Oxi gives me 8 CVs + Zadar for many more.
Maybe a filter?
What would you recommend for industrial? I was looking at Doepfer A-124 (Wasp), Bastl Ikarie and WMD C4RBN.
Definitely yes!
I was under the impression that Polimaths works well stand-alone, but I'll look into NUSS. Maybe I want to get into it and I just don't know it yet :)
Thanks for your comments, super helpful!!
That's the plan!
Maybe a filter?
Definitely yes!
-- Pe8er
Right on! :)
Re: Filters. These are a very personal choice, and I don't have much experience with Industrial, but I can say Ikarie and Wasp are highly thought of in general, and sort of "classics," especially the Wasp. I'd say go with your ears, though, when making a choice.
Re: Mixing. How do you plan on mixing your various voices and signal flows? I'd probably put this above even switching, but forgot to specifically mention it above.
Thanks a lot!!
I've got a RME Fireface that I use for mixing and matrix routing.
Hi,
Good choice.
I have the Warna and is good for mult (and sum) pitch signals. For mult gates or cv I use passive multiples (less money and less space).
Filter. Your voices have filters yet (Mother, Oxi and OneRoi). I'll buy a filter just in case you want to add a new "simple" voice.
I like Bastl Ikarie and Three Tom Steve's Ms-22, but filter are a very personal choice.
Modulation. Maybe some random cv generator. LFO's and enevelopes are good for modulation, but are "statics". If you want more rythmic modulation maybe a Sample and Hold, for example RND STEP from DivKid, 6 channels in 4HP. For dynamic modulation, maybe a classic, a MI Marbles clone.
Best regards,
Ferran
Thanks a lot!!
-- Pe8er
But will that handle modular signals within your modular rack? Mixers aren't just for handling audio signals.
For example, mixing two or more lfo's to create more complex/interesting control voltages.
Panning, crossfading, muting, are also things mixers can bring to the table.
Eurorack modules are typically "hotter" than regular audio signals, so usually some sort of output module is used to convert to regular equipment levels outside of the rack. RME Fireface may handle that, I'm not familiar with it, but if so, you'd then need 3.5mm mono > 1/4" cables, correct?
Hope that makes sense!
