Greetings. I am somewhat new to modular (although very much NOT new to synths otherwise). I am mainly a guitar player. I am going to use a Behringer PP-1 to route my guitar signal into Eurorack and use the PP-1's CV/Gate outputs to patch into two separate synth voices. Is there some sort of module that will allow me to patch the single CV/Gate outputs on the PP-1 into the CV/Gate inputs of multiple synths and also, at the same time, to in some way select which of the synths is active? I will be running the synth voices into loopers, and I want to be able to select which of the synth voices I am playing before it gets to the looper.
Shorter: I want to play one synth voice into one looper at a time, not both at once, and then switch to the other voice.
I hope this makes some sort of sense. Thanks in advance for any advice or any other thoughts on how to achieve this - I'm guessing someone will have an idea that I simply am not thinking of, and I would appreciate that input as well. Thanks.
Ron
You are maybe looking for a switch.
Some switch can change routings via CV or gate signals. Doepfer has some. Many other brands also do.
Some can be activated manually. Tesseract 8x8 buffered matrix comes to my mind, there are plently other options.
Slim: thanks very much. I'll look into switches.
I also need a switch.
Do you have a advice for a good switch module?
MN Jumbler and Patching Panda Rewire looks interesting to me so far.
But its hard to get them used on lower price.
Greetings
Chris
