a cool video :
synthesizer voice
https://www.eowave.com/modules/swarm
Has anyone else had issues with the sensitivity of the touch pads on the Swarm? It only registers about 1 in 3 touches for me in use, unless I lick my fingers.
-- chrisormitch
Gross haha
It probably needs thouroughly cleaned after being all gummed up by human secretions.
I bet it will work like a charm after that.
Electric circuits and spit don't play nice together
over:under
-- chrisormitch
have just received the unit. same here, the sensitivity not working fine, sometimes it works most of the times it doesnt, im about to send it back to the dealer...
Yes, it's not perfect and unstable for a serious project, but is very experimental and give you the opportunity to search new sounds. I recommended use by midi and not manual if you search a better touch. For manual use is not stable and give you bad surprises when you are in record mode.
