Hi everybody!
I started making music with modular a year ago.
Might be some kind of mid-life-crisis thing.
Used to be a teenager-dream when i saw Dieter Döpfer exhibting his cases and modules in a music-shop in Munich.
Now 20 years later, eurorack doesn't look so expensive/difficult/scarry anymore.
So i dipped my toe in!
I have a 19inch stage-case (6U) wich is housing 2 rows (82hp each) for eurorack-modules (PSU is a tipTop uZeus). The case is pretty sturdy, can be closed with a lit - wich is great for moving the rack around, jammin with a friend (maybe playing live some day). Not a beauty but a pretty budget friendly case (lots of material flying arround unused).
So it's supposed to be between a Studio-Tool and a live instrument.
I polluted the rack very slowly during the last year. As a long-time reader on this forum i tried to stick to some frequently mentioned tipps for starters.
- Don't get seduced by the "fancy" modules
 - RTFM before you buy a module to ensure what a specific module can do (and what not)
 - There should be a reasonable and usefull relation between the types of modules
(sound sources < sound modifiers < modulation sources < utilities) - Don't buy a huge bunch of modules once, go slow, enjoy the limitation, understand stuff and exhaust the functionalitys of things you allready got
I also tried to resist buying very much "pricy" modules, due to fact that i wasn't 100% shure if would enjoy eurorack on a longer term. So after a year of research, reading and fiddling with the view modules i own, i feel more convinced to go ahead with my rack. I tend to check the functionality of my rack by building pretty much the same in VCV to see what makes sense (and sounds good). With the last two modules i purchased (MATHS and 3xMIA) i got a lot more possibilitys to mix/combine modulation CV and fine tuning modulation CV. In generall, they helped me to understand stuff.
So far so good.
At this curtain point of my build, im a little bit helpless to reach for new Modules. I just don't know where to go. So i'm asking for some input, opinions and feedback. I have two modules on my urgent wishlist, wich are OCHD and VEILS. I think OCHD is great, kind of a "no regrets" or "tried and true" module. I start to realise the possibilty of automating stuff within a patch so i think more VCAs with mix could help for stuff like that (im not set to veils).
I dont mind diving into menues that much and i also have no problems with cheatsheets ;-)
But i also like "dedicated" modules.
As a broadcast engineer i have no problem with tiny buttons and technical stuff
I'm willing to break with my tipp 01 (fancy modules) ... wich i allready did with maths
I definetivly have some fx on my short-term wishlist (FX AID not available at the moment).
I really like distings stereo-fx but i want to explore other disting-algos and get a dedicate fx module on the long term
Meanwhile i have reactivated my old tc.electronic delay/verb ;-) to free the disting
I have some "fancy" stuff on my long-term wishlist wich is (in particular order): PNW, Mimeophon, Data-Bender, Wogglebug and maybe dozens more. But those wishes are pretty random - I want to get the basic stuff covered first
Last but not least ...
I sequencing stuff in change with a keystep, SQ-1, sometimes with 2 channels of my Elektron Model.Samples.
I record my stuff with an desktop mixer, monitoring and recording with focusrite scarlett. Like a lot of people arround i like to work without the computer, except mixing and mastering tracks. Right know i'm more focused on experimenting and kind of rehearsing live performance.
Musically wise i thing i would describe my musical outpout as kind of ambient, dubish, technoid stuff.
As a kid of the 90s, aged hip-hop-head and rap/poetry artist im also attracted by the relatviely knew genre called "mod-bap"
I'm not into generative but i wouldn't mind to build patches that are kind of selve-evolving developing over a certain period of time.
Right now i'm not into swapping modules since i like all of them.
There might be a bigger cab in the future - right know i try to fill the case
Greetings from Munich and thanks for taking time,
Max
