Yes I apologize for not explaining it in the post. So I have an separate groovebox (EMX-1) which would be for making drums and some synths (speaking for a live situation). So the eurorack would be for more percussive sounds, leads or riffs. Wanted to do it a bit like ASEC (check him out on youtube).
  DFAM would mostly be for riffy hypnotic leads.
  I would also like to use this setup in my studio for now as I do not have enough money to make two cases (one for studio and one for live).
  In conclusion the rack would serve as the main synth and percussion part for live techno.
  -- Obscur
So - if you are using an external midi capable device in any way, I would recommend a midi to CV/gate converter right off the bat for a few reasons. The first being obvious CV/Gate patterns via existing Midi machines. Another is for setting up utilities like clock dividers, reset trigs, slow/odd sequence steps/timings, and I'm sure there is more that I am forgetting but external midi sequencers are highly capable of providing great utility to your modular setup (especially if you want one modular case for everything).
I cooked up a little rig quickly attempting to use some similar modules and some completely different ones. The artist you posted is a fairly popular style of techno so you should easily be able to achieve that with the DFAM. Using it in combo with the Morphagene might yield cool evolving patterns as well as an audio sampler so I kept that in there (and for background textures etc.). Mimeophon is great for an effect as it is delay/reverb-like.
The midi thing is just a decent midi module I have personal experience building. Pretty simple to work and good build quality from Befaco (I get the DIY kits). Muxlicer is a great sequencer as it has lots of utilities built in, as well as the ability to be manipulated via LFO to totally mess up the sequence order in-time. So plugging percussion trigs from the channel outs summed down into the Bytom and you get cool trigger sequences for drums/bass - mute/swap/mix them w/ the Mutes/Switchblade modules. Also swapping the CV from either the Mux or the DFAM or Midi pitch CV is great for getting a live groove vs a pre-recorded groove.
I'm not familiar with the Basimilus, but I know it is a drum module that can be 'struck' or 'trigged' so that's a bonus. You can plug it into optomix and get even chirpier 'plucks' and run it wide open/drone, or use the onboard decay control to shorten it up within the module itself. I kept the Belgrad filter in cause its multi-mode which is good. Optomix for the ability to 'duck' voices via CV or audio/mixing/vactrols are sweet. Maths cause maths.
Mutes for audio muting and then Mixer to finish it off - I didn't know what you would be into, but I find I like blending the audio together and summing down when I perform so I can get total control - so I threw the ALM mixer in for spatial and volume easy mixing solution w/ Ext In for external gear (not sure if the gain will be high enough though - didn't read the manual).
Mimeophon as a end of chain effect for good measure as it covers delays/reverb washy stuff.
There isn't a lot of "voice's" here - but if you pulled the DFAM that would give you more room for extra LFO's, some type of Turing machine sequencer would be ideal, maybe more elaborate mixer, sample and hold, and maybe another standalone voice in there if possible. With clever use of the Morphagene, you can get away with less modulators, as you can record knob movements and then play them back with audio recordings that layer up on stuff which could be awesome. Or even use Morphagene for drum loops along the rest of the stuff - who knows.
