A synth designed to work like a bass guitar. Takes advantage of the surplus of "quad" modules out there. Bass has four strings so we've got four pressure point pads, triggering four envelopes, controlling four VCAs, fed by four Oscillators which are pitched by the four CV converted midi voices. It then runs into a compressor. Because what's a bass without a compressor. Then into a parametric EQ with all the channels running into a make noise panner, so that you can get some interesting harmonic tremolo options.
