Overview
- 2 Sound Sources: Maths CH. 4 (cycling @ audio rate), Basimilus Iteritas Alter (via Maths Channel 1 Unity Output)
- BIA goes direct out (with Amp CV modulation from Maths OR Output, chose OR because 2hp VCA is not bipolar), while Maths CH. 4 is filtered at Cinnamon then sent to Quad VCA and out
- Maths modulates BIA Trigger In as well as CH. 4 amplitude cv
- LFO's from DixieII and Peaks, as well as a Pitch Sequence from Micro Sequence (which is both advanced and receives a separate Gate from Tempi) bring rhythmic and textural variety to Maths CH. 4's amplitude and filter cutoff, as well as to BIA's various timbral parameters
IMPORTANT, In DAW
- Used Klevgrand Brusfri to cut down on noise from the modular
- Duplicated the BIA Input, where the duplicate is centre panned and only plays frequencies below 300Hz
- Maths CH. 4 is panned left 20L
- BIA unfiltered is panned right 15R
Octavian
