hey guys...
just one short question.. with what would you fill up the last 6hp ? :)
VCAs.
noodle_hut
Doepfer A-185-2v Precision Adder
Somewhere before the oscillators.
-- noodle_hut
Can you tell me why you think this is important for this case and what does it? im to new in this stuff to understand this solution.. :)
noodle_hut
The precision adder lets you switch multiple oscillators/modules up or down octaves without spreading oscillators out of tune with each other.
Flipping a switch to raise or drop an octave is a convenience compared to re-tuning with a knob, and more accurate than most active multiples.
You can also use it to transpose a sequence to another key with a second sequenced cv.
The first channel lets you ease in with an attenuator, so you can add a bit of wobble or other modulation fun to multiple voices.
Or you can use it to goose several modules a little bit into tune, all at the same time.
I guess it's value depends a bit on if you are going after playing notes 'in tune' with something else or itself.
I don't mean that negatively.
I know a lot of synth musicians don't want anything to do with that, and that's ok.
We forget after doing so much in digital, that analog is so squishy in its tuning.
The A-185's "precision" keeps combining or switching 1v/octave cv-s dead on. Really handy all the time.
You usualy can't go wrong with VCAs. Perhaps something like the Tallin by XAOC? Or something more utilitarian like Blend by After Later Audio.
