hello
I need a bit of help on a better power solution, but I'm a bit of a noob when it comes to electricity and such.
here's my issue :
I have an alm case without the 5pin thing that some moduels need like the bluebox, that I'm using. well to fix it I installed a ms4 pod power module in the case, just to run the bluebox.
this works fine, but now I have to use two power supplys (that I hate)
I would like only one cable.
can anyone come up with a solution that doesn't involve wiring stuff up my self.
the ms4 power modul have a power out (fir linking to other ms pods). I was thinking of linking from the ms4 to the alm case, but ChatGPT told me it was a bad idea.
please help 🙏🏻
Invest in a Synthroteek Cheeks of Steel at whatever size you wish, and a Trogotronic m/15 PSU with HQ busboards.
Both are reasonably priced for what they are and are a great skeleton upon which to build a system in which you won't have to power about power overhead or running out of space for quite a while.
I got a troggotronics power supply because its the only one I could find that have the necesary amount of power and pin headers.
Ive been super happy with it. However, it will likely require a minimal amount of wiring. I remember it being quite simple though.
