want 8 stage seq going to 2 sep VCOs but want to be able to have one VCO hold the pitch CV whenever I want while the other keeps incrementing, so need two sequencers with same pitch settings and rate, seq A goes straight to VCO1 as normal, seq B has to be the 960 for the ind gate ins.
- Clock Vgates and time suite with same clock value through switch getting diff sync rates backplane
- Vgates outs 1-8 imto octal VCA ins 1-8, VCA outs 1-8 patched to 960 gate ins 1-8
- Q170 gate outs 1-8 into octal VCA ctrl ins 1-8
- start with all 8 pads high/Q170 all gates high, means both VCOs will be playing every note
- selectively disable Q170 gates to have VCO 2 hold & sustain pitch for the previous step while VCO1continues to increment pitch
Detail
1 Multiclock DIN sync>time buffer>8s thru 32nd pulses to switch backplane, then to Moon 568, volt ministore 4 and Vgates
2 start pulse from time divider resets Vgates, switch for time divisions, 568 and VMS4
3
