*all black modules are by Audio Parasites where possible, then Mork Modules, then others, selected what was available in Mod Grid for convienence, silver and white modules are not for me - Midnight all the way....
*all knobs, caps, socket screws etc are colour coded, Orange/Clock, Purple/Reset, White/Audio, Black/Trigger, Pink/CV.
*spaces in 1u rows are for perm.. patch cables to be routed under modules for less cable clutter with right angle headers, ooof.
*all screws are nylon
7.0 (25th July 2025) full rebuild to dual Amalgamod case, not worth detailing all changes, other than, LOTS of changes
6.4 - (23rd June 2025) moved to 2nd Amalgamod case from 84 intellijel, and adjusted modules to suit
6.3 - (9th May 2025) removed legacy BIA and Manis, added BIA Alia, and SY0.5 revised rows and mixer location, removed Motion Mtr, added Gliss x1 for more clocked automation and more Buff/Mults, changed 4ms to Catalyst Seq, removed WMD Direct IO (didn't need it in the end) full overhaul of locaitons of equipment for cable cable access to equipment used for performance orientation. - even more fun
6.2 - (22nd April 2025) removed juno and juniper filters, swapped in Ge0Sync TB-EF and O, also removed Scales and Memetic (wasn't needed anymore, can go in another system) for Lapus OS and to make spaces for TB-O above. Moved Bass/Melody compressor to 2nd rack, relocated PM-MKII-Returns to top row, and installed an WMD Axxent. all up - more fun
6.1 - (16th April 2025) added 4 channel panning mixer, dual HP/LP filter, 4HP AttenV/Offset, removed UVCF Filter, Axxys, Motion MNTR - general better overall bang for buck and added live performance mixer for additonal drum voices into a bus
6.0 - (10th April 2025) general build from previous retired builds, included dual metroploix / metron for performance personal preference
2 Racks
*built and active (22nd March 2025)
First - Amalgamod - Drum and Mixer focus
Base - 7u 104HP
Top - 7u 104HP
*built and active (10th April 2025)
Second - Intellijel with custom joiner to match Amalgamod - Voices focus
Base - 7u 84HP
Top - 7u 84HP
custom alluminium connection so as it aligns with Amalgamod system on bench top
custom allumninum closing system so it can be transported patched and closed, and transported like the Amalgamod system
considering a 2nd Amalgamod case as they are superior in so many ways, just an amasing case setup for transport
