at around $3,000 this configuration might actually fit into my budget, and it still meets my total production capability aspirations. how do i go about getting a 1x3u 100hp case and what would that cost? can someone please critique this design? im looking for genuine feedback. i think i covered all my bases, but it would be nice to hear some genuine comments from the community...
please take a look and tell me what yathink
peace โœŒ๏ธ๐Ÿ‘พโœŒ๏ธ.
ok, so i found a 7u 104hp case on sweetwater and im only planning on filling 104hp of 3u... but i just maxed out the configuration just to see what it would look lile completely full. ...
please, please, please, comments.
peace โœŒ๏ธ
i feel like im getting ignored. im finally considering spending real money and i cannot get a single comment of feedback.
โœŒ๏ธ๐Ÿ˜ขโœŒ๏ธ.
If it makes you feel better, you're not the only one haha
I only comment if I feel I have experience of the modules, and in this case its Ochd and Pams so I'm no use to you.
it just feels like, maybe, i have unlocked the "secret sauce" and... i just want someone to acknowledge this congratulate me or calmly explain why i am actually crazy, etcetera. ...
i feel like maybe nobody has ever crammed that much into 3u 100hp in terms of total standalone functionality in the history of eurorack, and i want some credit. etcetera.
also, see how im just having fun with the third row? why cant i get a single comment like "im sure youll have fun playing with those 4 dreambots if you complete the case."
it feels like nobody here is at all focused on production at all. i cant get a single person to comment on my designs as total conceptual instruments. bandinabox should be the aim.
im done ranting.
peace. โœŒ๏ธ๐ŸคจโœŒ๏ธ...
It's about as close as I've seen you get. I still think this is a work, but I'll play along:
I've made some quality of life changes while still trying to keep what you have here. Rather than explain all my changes, I'll just say that if there are any you don't understand or appreciate, I am happy to answer any questions and provide alternative solutions. I can give you a rough overview, though. I will say is that I think you will be much happier avoiding those 2hp drum modules, espcially if you don't give them enough space. They are very difficult to use in a big system with lots of cables and options. You should be able to run lots of layers this way, as well as be able to sample and combine elements using the Bitbox so you can use the results of those patches while running other patches. "Band in a box" will always be better with a DAW, a more streamlined hardware workstation like an MPC, or at the very least as a large system built gradually by figuring out what you want from each "bandmate" using experience and going piece by piece. But you can totally do multiple things with this - bass, lead, chords, drums, and other samples all simultaneously. You'll want to throw a MIDI keyboard in there for the Demon Core, and you'll be a lot happier with an external mixer if you want multiple things going on like a full band, but it should kinda work then. Kinda.
No one else but YOU will be using your system. So if you're happy, then that's all that matters..... I can tell you are passionate about your choices, and that's the beauty of eurorack. However, I would reccomend starting with only a handful of modules (perhaps the core ones) and thrououghly learning them will show you what your system needs. From my experience, I've had "ideal" systems in mind, but they never truly stayed 100% true to tuition and changed as I purchased more.
I will agree you've covered nearly all of the bases for a groove box (my inspiration aswell), but there could definelty be better choices for the limited HP you're working with.
Also, having a pams and a clock module is a little confusing in such a small system. Maybe replace one for some more HP.... And for my last two cents, dont limit yourself on the modulation (LFOs, ADSRs, Logic, Ring Modulation, Attenuators etc.) Part of the beauty of modular is modular. Maybe look at the ochd expander.
the very first 100hp posted is the core idea.
the third row in the second post was just to "fill" the case i was looking at and was just to experiment and have fun with coupling chaos oscillators. i did not like your new modifications zachsname. i wanted the drum sounds to be just set it and forget it and the 2hp modules do that. also, you dont seem to get what the strange-r does and how it fits into my design + focus on production.
believe me, i know what that 1st 100hp does and i would be happy with it. the third row was kind of a joke. your new design looks like a mess, zacksname ! focus on design.
nobody gets the concept. oh well. peace โœŒ๏ธ.
.edit.
i know i dont need the pam, but its the most convenient way to keep the strange-r and clockwork in synch, plus, if i wanted one or the other in double time, pam could do it.
also, zacksname. i was thinking a lot about signal path and cable management that your new version ruined. with the 2hp i can cut out each part with the sir mix a lot mutes.
everything is a compromise and i think i wss making a lot of good ones. you dont have to use any modules. with your new design you were taking away some of the creativity. ...
(why is nobody getting my concepts, etc. ...)
peace โœŒ๏ธ๐Ÿ˜ŽโœŒ๏ธ.
What's the concept?
I think you should just buy it. The rack itself is so much easier to bounce ideas off of than any individual will be.
the concept is live improvised chordal progressions with a generative element on the strange-r controlling a demon core, and a set of sequences programmed into the clockwork where i can mute each part individually on the sir mix a lot, with full envelope, filter, modulation, and effects chain, with no extra gear needed in any way.
too abstract for you, zacksname? peace โœŒ๏ธ
.edit.
also, the concept for the 3rd row is experimenting with the ways the dreamboats can couple together, which is why i have the octasource and joysticks and funny noise module, so i have enough options to explore very deeply into the possible soundscapes i could unlock.
(but it was mostly just a joke. im not sure exactly what i will do with the 3rd row etc.)
peace
โœŒ๏ธ
hey, zacksname. i fixed the 3rd row just for you, etc.
.edit.
also, i wanted to point out, i came onto this forum with a 4x 12u 100hp concept, and got it down to 1x 3u 100hp (if you only count the 3u 100hp i have any intention of acquiring.)
thats a 16x reduction in complexity. i feel like modulargrid should give me a badge for this.
etcetera. peace.
โœŒ๏ธโœŒ๏ธโœŒ๏ธโœŒ๏ธโœŒ๏ธโœŒ๏ธ
