what power supply do i need to run 2000mA of modules?
any advice?
thank you
Howdy!
I'm assuming that's 2000mA of +12v, so to give proper guidance it would be helpful to know what the -12v draw of your modules is. These power supplies output 2000mA +12v:
TipTop uZeus: https://modulargrid.net/e/tiptop-audio-uzeus--
4MS Row Power 45: https://modulargrid.net/e/4ms-company-row-power-45
Konstant Labs StrongPWR: https://modulargrid.net/e/konstant-lab-strongpwr
That said, if you know your modules for sure draw 2000mA +12v, you'd actually want a power supply that gives you an additional 20% or so (most module power ratings are averages, so you want to be able to handle fluctuations as well as onrush when you first power up the system). As far as I can tell, there really isn't much for power supply modules that do more than 2000mA, so you may be better off getting a case with integrated power supplies. The TipTop Mantis case is rated for 3000mA +12v and is generally regarded as the best bang-for-buck case on the market.
Cheers!
