This was a tricky, end-of-chain build because there aren't many 104hp cases that offer the module depth and power draw that's required to satisfy the inclusion of a Trogtronic m/277, which eats up a whopping 760 mA on startup for the first 10 seconds once the rack is turned on and has a 58mm module depth (quite a hefty addition).
To make this work, you'll need something on-par or better than the Eowave 3U Skiff 104HP, which offers 60mm module depth over 99HP of the case (40cm over the power bus), 1500 mA on +12v and 1000 mA on -12v, with 500 mA on +5v when using a 4a PSU.
