Hi all,
Second post here.
Just a question as stated above. I have contacted ModBap weeks ago but no answer from them. Maybe someone knows.
Here it is: while using the 2 separate outputs on the Osiris, (one for the voice and the other for the sub OSC), I get a non stop sub out even when stopping my sequencer. Output is connected to a separate input on my mixer (4ms Listen4). I do understand that the sub out gives a full volume, which is not a problem as I can tame it down with the mixer.
The weird thing is that when I hit stop on my sequencer, the sub out keeps delivering its full volume out. It will only stop on a double press on stop on the sequencer. MORE: when double pressing stop on the sequencer, I still get a signal (audio?) coming on my mixer (4ms Listen4). I do not hear anything but it looks like something is still coming out. Confirmed by the fact that I get the same visual signal on the A/B inputs on my Octatrack. Same as the 4ms mixer.
Any idea?
Thanks for any hint in advance, much appreciated as ever,
Olivier
