Hey gang, another tips and stuff video on the channel, this time, it's all about the Westilcht Perf │ Former.
Hi, alternative MEBITEK Firmware
Vinx77
Vinx PER|FORMER firmware – update v0.4.2 – April 23, 2026
https://vinxscorza.github.io/performer/
https://github.com/VinxScorza/performer/
Performance-focused and exploratory.
A DEMO / WALKTHROUGH VIDEO is now available at the following link:
What I’ve done in this version
• Aligned the Variation semantics, which now behave as a per-step keep/replace control against the original material in both Generators
• Reworked Generators footer/context layouts for a more uniform workflow across all Generators
• In Chaos, clamped Note and Note Range generation to a -24..+24 semitone window
• Made all Generators enter on the original version: the first generated Sequence now requires an explicit reroll action
• In 16-step Editing Mode, updated playhead feedback with dedicated state
• Fixed Voltage Mode behavior on Arp and Stochastic tracks (to be tested)
Also, in earlier versions
• Full evolution of the Generators ecosystem
(Random, Euclidean, Acid, Chaos: Vandalize / Wreck / Entropy)
→ now more coherent, with unified preview/apply safety and a shared playable workflow across the machine and Launchpad
• Added an experimental 16-step Edit Mode on Note Tracks (tested on LCXL, to be tested on BSP)
→ step editing via external controllers with 16 knobs + 16 pads
→ knobs = Note for the visible 16 steps
→ pads = Gate on/off
→ navigation across longer sequences in 16-step sections
• Improved Launchpad integration, with Generators Mode, Inits, and Undo/Redo
• Unified preview/apply workflow with safer destructive operations (1-level Undo/Redo)
• Unified Init behavior (Layer / Steps / Seq), selection-aware with consistent fallback logic
• Refinements in step selection (shift behavior, selection-or-all logic)
• Improvements in timing, clock/reset handling, and edge-safe sync
• Curve track extended with Gate Offset and Gate Length
• Improved handling of scales and operational limits
• Reduced memory footprint and improved runtime efficiency
• Simulators aligned with actual firmware behavior
• Expanded documentation, with a new manual featuring improved search + full Launchpad cheatsheet
• Overall ecosystem cleanup (site, docs, simulator, references)
And many other small improvements that add up, including a near-complete refactor of the Launchpad code
Full feature list
https://vinxscorza.github.io/performer/features/
The goal is to make the PER|FORMER more playable in a live context, while keeping it open to less predictable workflows.
A solid machine for performance, but also a crazy one for experimentation.
I’m kinda losing my mind over this fork.
If you find it useful, consider donating
https://vinxscorza.github.io/performer/donate/
If you notice any bugs or weird behavior, feel free to report it via GitHub, email, here, or wherever you like.
This fork has been moving fast — and since it’s just me, feedback really helps.
