As the title suggests,
When using a sample playback module with v/ oct pitch control
(let's say the 2hp "Play")
what pitch should you record a sample at to get accurate v/oct pitches?
That is, if I were to record a single piano note, so that I can then sequence the sampler to get a pitched piano melody,
should I record a C note?
does v/oct have a fundamental root note it works from?
or is the standard approach to not worry about it and then tune with the v/oct knob.
Thank you
wishbonebrewery
Ideally if you want full range I seem to recall you should have at least 1 sampled note per octave, though I'm pretty sure the 2hp won't accept multi-samples. So if you keep your playing range within 8 notes each side of middle C you'll be about OK.
I once sampled each note of a Roland MC-202, editing each for sustain loops, and put them into a Reason software sampler, that was very boring workflow!
so is it more a matter of just choosing what note to sample, and just consistently using that for all samples?
wishbonebrewery
If its just 1 note then go for middle C, though it could sound a bit rough as you go up and down the full scale.
If you have the option of doing this in Software first you could experiment and see how that 1 note works up and down the keyboard.
Sweelinck
When sampling an instrument for tonal music, use the 'cycle of fifths': F, C, G, D, A, E, B, etc. But, as explained above, this assumes the ability to multi-sample...
See this rather complete article on piano sampling: https://audient.com/tutorial/pianosample/
For the rest (e.g. atonal percussion, concrete or experimental music), there is no rule.
But, in a modular, filters, wavefolders, envelopes and vcas, will be very useful :))
Maria44566787765
I can tell you that in order to play samples accurately with v/oct, you need to determine the sample's pitch, and then set the appropriate pitch value in your synthesizer or sampler.
If you're going for a single note .. use one an octave (or two) above middle C. I find they translate down beautifully, and while probably less of an issue on modern equipment... they take up less time/disk-space (shorter waves).
