First jam with the new Make Noise XPO. It sounds amazing. This is a one-take, raw performance recording. No additional processing on the audio.
Here are the rough patch notes:
XPO to X-Pan to QPAS to Mimeophon
VPME QD for Kick and Clicks - Clicks go through Chronoblob 2
Rene X channel driving the main sequence - goes into XPO main 1v/O
Rene Y channel is driving key changes going into XPO 1v/O second input
Rene C is sequencing Blades cutoff which is filtering the VPME Clicks
PNW is modulating Snake changes on Rene X
Planar 2 X axis is set up to drive QPAS cutoff on the second input
Planar Y axis is driving the XPO FM level
PNW is sending S&H to QPAS main cutoff
PNW is pinging the left wildcard input on QPAS with a euclidean rhythm
Sloths is modulating QPAS Q level
XPO Saw and Sub outs are going into X-Pan Aux and Maths is fading them in and out
Tides is modulating Fade and Pan on X-Pan A & B Channels
Diode Chaos is modulating QPAS Radiate levels
Ochd is modulating Mimeophon Zones
Batumi is modulating PWM on XPO
Quadrax is enveloping XPO square waves with a sharp attack and longer release, and enveloping the wave fold outs with a soft attack and sharp release
Performance Mixer brings it all together and Strymon Starlab provides some reverb through the Aux send/return.
