have conviced me to keep it well preciously!
It's Xaoc. Which I think might be Russian for "kickass!" There are so many sneaky and hidden functions in those (particularly when you add a module's expander) that you can just go on and on with them and it'll take you a while to exhaust the possibilities with ANY of their stuff. Batumi and Zadar are more or less "go-tos" for adding big bangs in small spaces, for instance. And when they go ALL OUT (think their Odessa module here), it really IS all out! Feckin' amazing design going on there...on both sound AND ergonomics.
@Lugia - it's chaos, not kickass, but they might be that too!
Oh, yeah...I know it's supposed to be "chaos", but I see a slogan possibility there: "Xaoc. Chaos. Kickass."
hehehe I knew you knew!!!
maybe "It's XAOC, kickass chaos" would be even better!
Like "It's Bond, James Bond"...
And if you can get someone to intone that slogan with the proper accent, it would be the PERFECT opening card bit for one of their promos. Yep...I like!
I only have a VCA and the multi from XAOC, but I can feel you're totally right. The design is one of my faborutes on the Euro sphere, and yeah, I almost clicked "add to cart" a few times bout the Batumi. Odessa seems to be a wonderful generator...
@Lugia
-- -ADR-
And actually, one of their least snazzy modules is perhaps one of their very best: Bytom. I honestly don't know of any other pulse integrator in Eurorack that offers the capabilities this does for that price, with their excellent ergonomics in effect as usual. IMHO, if you've got a lot of clock manipulation and logic happening, the Bytom is a killer module.
Isn’t the Bytom simply a switched OR combiner?
-- stripou
Sort of. Most times that you see a typical "diode OR", it's sort of limited in capability as far as inputs are concerned. The Bytom, however, contains three of these sorts of circuit, and you can combine them to create a 12 input OR. Which is a tad silly, but which I can guarantee can actually happen. But the nice thing about the combination switches is that you can switch in and out of incoming pulses with a little creative patching and the use of the link switches, so if you put an output for, say, a shift register on the top output and more typical clocking on the middle, you can cut the clocking for the shift register and have it "hang" while the other clocked modules keep on going.
About the closest thing along these lines that I can think of are several different multi-ORs which can switch between one of two busses. The Bytom's routings, however, offer some interesting potential routings that those can't, such as combining entire busses.
GarfieldModular
Hello Jim,
Ha, ha, great one! Perhaps you can sell that to Xaoc Devices in exchange of a new great module or something like that ;-)
Kind regards, Garfield.
