Hello everyone, first post here and quite new to the Eurorack world so I’m after a bit of advice!
I am having a little bit of a routing headache. For context, my setup is an Elektron Analog Rytm, Analog Four, Octatrack and the Eurorack.
The way I have it set up now is I’ve got my Bitbox + Loquelic going into the Tex Mix (borrowed from a friend) then out via the Master to my Analog 4, and then that goes into AB inputs of my Octatrack.
Then I’ve got the Analog Rytm going into the Tex Mix and the Basimilus taking up the last spot (I prefer not having audio go into the Rytm as the external mixer page is non existent unlike the A4). Those 2 are set to cue, and go from the monitor out of the Tex Mix into inputs CD of the Octatrack.
What I’m trying to achieve is to have the melodic stuff on one side, drums on the other and use the OT as a final mixer/mangler. But as you can see, it’s quite a convoluted and messy set up. Add to that I can’t use send effects with the drum modules as they’re on cue. Is there any better way to do this? I feel like there is there a simple solution I’ve completely overlooked and I’m hoping someone with more experience can help.
My second question is a more general opinion/advice one. I’ve linked my rack so if you can, please give me your thoughts on it and whether you think I’ve omitted something/think there may be something that would be a good addition :)
I mainly use the Eurorack in conjunction with the 3 elektrons so in terms of voices I think I’m pretty covered (though again, I’m new to the modular world and am very open to different perspectives).
I’ve got 10hp free but I’m open to switching, buying, selling etc. The music I make is quite heavy, 100-130bpm EBM/darkwave/techno type stuff though sometimes I do switch it up to some drum n bass/breakbeat if that helps at all.
Thanks very much.
Edit: it’s not showed up yet but I have the mono not stereo tex mix inputs.
