Hi guys, initial thoughts for first setup
https://cdn.modulargrid.net/img/racks/modulargrid_2241266.jpg
Trying to make a little techno sound box that I can jam on to (kinda) get me off my laptop. Currently living out of a van so the travel friendly case is a must atm. I want to sequence from Ableton and record back in and apply effects etc with an audio interface.
From videos I've seen the maths gives loads of flexibility and mod options. I love the sound of the QPAS and like that the plaits has a diverse range of sound sources.
Do you think any modules need swapping out? Any modules that are not needed?
Thanks in advance :)
First, turn on the headlights:
Then forget about this setup. Sorry, I don't have the strength of @JimHowell1970, or some others, to explain things in detail. And there would be too much to say.
In exchange, if techno is your thing, this rather famous tutorial from mylarmelodies; you'll find more on YouTube. I sincerely hope that this will help you.
I agree with @Sweelinck, particularly about watching that video. If you haven't seen them already, Mylarmelodies' videos are immensely helpful in putting together a rack and just understanding modular in general.
As for your case, my first thought is the QPas is taking up a whole lot of territory. It may sound great, but if you can't fit anything else in the rack to use with it, it won't work for you the way you want it to. To be honest, Plaits is so robust and flexible (particularly with the new firmware update) that you could probably get away without a dedicated VCF.
Next, you need modulators. Things like lfos that will give movement and flow to your patches and let you change parameters without futzing with tiny knobs like on the 2hp modules. 2hp makes great modules, but you really need to think about usability and spacing with their knobs. For example, would you be able to play with the Mix's knobs during a live set without accidentally messing with Plaits' settings? Back to modulators, one great module is DivKid's ochd, 8 triangle lfo's in 4hp, it makes really organic motion. Doesn't help with other wave shapes, but I love it. Though it's a bigger footprint (10hp), Xaoc's Batumi is a classic and gives you access to a wide range of lfo options. Amazing when self-patched, too.
How about percussion? It doesn't usually makes sense to waste space with drum modules if you don't have much hp to spare (use outboard gear for that), but if you wanted everything on rack, something like Erica Synths Pico Drums (3hp) might be interesting. If you are using off rack percussion, or just because it's awesome, then something that can send out triggers would be helpful. You could use that to build patterns or any number of other useful things. Of course the Pamela's New Workout / Pro (10hp) is a standard, but there are other, interesting ones like Euclidian Circles by vpme.de (10hp) or various logic modules (which, in fact, Pamela's can also do).
Finally, but maybe most importantly (@JimHowell1970): utilities. Your case already comes with a good starter pack (attenuators, mults, vcas, mixers, Maths), but that's really only scratching the surface of what's out there. You can squeeze so, so much life out of your system using utilities. Also, they're often cheaper than the sexier vcos and vcfs, so that's a plus. Something like Ornament and Crime (particularly with hemisphere loaded) gives you a huge number of utilities and therefore flexibility in something like 8hp, depending on who makes it. I haven't yet used it myself, but Expert Sleepers' Super Disting EX Plus Alpha is a monster for utilities (also 8hp). While they're not very fun to play and do have some menu diving, either one will open a ton of doors to different tools that will change your modular experience for the better.
Hope that helps, and good luck!
(edited 'cuz I thought of more things to say)
Hi mate, thanks for the detailed feedback and suggestions. That gives me a lot to go on!
Having been mentioned twice in this thread, maybe I should weigh in a bit...
  1. whilst I can see the appeal of the tiny case - it'll fit in your handbag (or purse, if you're American) and they're on the cheaper end of cases - they're not really very good for beginners...
beginners need space to add modules to find out what they actually want and the modules that they really need to support them... part of the appeal of modular is that you can reconfigure your synth based upon how you patch it and having (over time) the ability to add 20 modules or so is useful as this will open up a myriad of possibilities in terms of patching which cannot be achieved with the contents of this rack... not buying a decent sized case also leads to the slippery slope of more cases - I should know I strated with a small (6u 72hp) case and having nearly filled it within 6 months bought a mantis - so I could fit maths in... I now have 8 cases...
also some small cases are quite shallow and won't fit some modules in (2hp, for example, as the pcbs are perpendicular to the panel and mot parallel) which can result in people using standoffs which is all very well until you manage to stick a patch cable in hte side and short something out...
go for a mantis (still inexpensive) or one of the intellijel performance cases if you must be tied into unnecessary things like output modules and midi in) they are still quite portable - I've taken my mantis on planes, trains and buses many many times and not had any issues
if you absolutely must have a tiny case - start with a bigger one work out what modules you absolutely must have in it and then buy the smallest case you can to house those - buy only once you actually know what you are doing...
MylarMelodies and others who show off tiny systems on YouTube are often only using them to highlight single modules or patches... having taken a few modules from their bigger case(s) and will then re-arrange them before the next video... and whilst it is possible to build a 'techno groove box in 62hp' it's probably not going to keep you interested for more than a few months...
  1. work out the modules you want and then work out what you need to support them - and leave at least 20% if not more space and then find a case that can house those modules - and can power the extra space when filled - I always estimate 10mA per hp per rail - and then allow at least 20% headroom on top of that...
  2. utilities, utilities, utilities... see my signature for some hints, but I'm not really talking about O&C or Disting EX - which can be useful but tend to end up being left as one thing when a dedicated module probably does it better* - I'm talking more about really basic things like vcas (you may or may not need a lot of these), switches, mults, attenuators, attenuverters, logic, clock dividers, and mixers... and whilst these can be inexpensive (doepfer and ladik, for example) they do take up space...
  • my disting mk4 was used almost exclusively as a tape delay for years
  1. ergonomics... small modules with tiny knobs do not make a pleasant playing field - not only do they need to be separated (you've managed to do this quite well) but they also need to be not next to other modules that either have jacks next to them that you will use or knobs - as you will not be able to get to the knobs to adjust them once patched without resorting to tweezers - which can be frustrating, to say the least
