No user found with username MCGM
I soldered all the bits on a kit from Pusherman https://pushermanproductions.com/product/full-kit-mutated-rings-w-black-aluminium-antumbra-panel-smd-pre-soldered-pcb/ last weekend, followed the calibration procedure and all looked to calibrate ok.
But I notice when playing notes on the Beatstep Pro that the upper keyboard ranges seem to all be the same note passed a certain point which makes me wonder if the Pot positions should be centered or something versus all set at zero prior to calibration.
Any thoughts??
Thanks
I've just tried a re-calibrate with the Frequency knob set to 12 o'clock and its made no difference, the notes are all the same from G upwards though going down the octaves is totally fine.
... the notes are all the same from G upwards...
-- wishbonebrewery
Dont't know if this is helpful...
I tested mine by routing the pitch input through the mordax data voltage monitor.
My Rings takes voltages from 0.0V to 5.54V. Everything higher than 5.54V is ignored.
Understood.
But Yeah, I'm not sure that helps or maybe it means I'm actually calibrated alright.
Testing the Beatstep Pro on a regular Oscillator gives me the whole keyboard range without problems.
