So, If I were to pick up a Korg SQ-1 or Tiptop Audio Z8000 I would get variable sequencing to go into it? The previous owner was using Native Instruments Maschine MK3, Maschine Jam and his PC, but decided to just use the reaktor 6 program that came with the software, it has WAY more blocks in it then he could ever own, hence the reason I picked it up.
  If I grab a sequencer, do I have enough in the modules to have some fun? I have plenty of cables and splitters to work with.
  Side note, what would you put on the ardcore? There are alot of sketches out there (no real VCA though).
  -- abigroot
The SQ-1 would be an nice entry point into sequencing and not a big hit if you decide to go with something beefier later.  You certainly have enough modules to have plenty of fun once you add a sequencer... or even plug it into your computer sequencer.  My main point is that using a computer sucks a lot of the "fun" out of modular... especially if the computer isn't ergonomically situated well and you have to move between your computer and your Eurorack.
The Braids module is going to be the easiest to deal with at first.  But you're going to have to learn all of its features before playing with it.  It can fully produce sounds by itself or be used as more of just-an-oscillator.  The Hertz-Donut is a complex oscillator that will probably need to be run through one of your filters and a VCA at a minimum... but it will offer the most "fun" as far as modulation possibilities via other modules.
You have more than enough here to keep you busy for several months.  With that time you'll learn which modules you really like and what you're willing to part with.
