CarlosUnch
Here is my build.
As you can see it's pretty simple, built around Plaits and Clouds which looks like a good match.
ΒΌ" line outs to record with my interface and headphone out. (needed)
FX loop to use external pedals. (exchangeable if better function)
Pamela's to put everything to work.
Midi in because I can't find better use for 2hp left. I have some nice Midi controller apps and could also use Ableton or my Cosmic Music Box to trigger things. (exchangeable if better function)
I was also considering Ears by MI to use my guitar or synths with clouds but I think S.B.G can do that already, am I right?
I plan to fit this into a Doepfer A-100 LC1.
Any module/function I should consider changing or adding onto a bigger case?
Thanks in advance!
Looks like a lot of fun! Have you thought of a function generator, instead of Pamela's Workout? Something like "Function", or even "Mod Tools" might give you a bit more by way of modulation. I was always under the impression that Pamela's Workout was akin to a clock generator, not so much mod source -- just my understanding on it, though.
When I started building my rack(s), I based them on systems that were already existing, and I know Perfect Circuit has some small systems like this that might serve as a good template.
Keep it up!
