Hi everyone,
I am starting to build my rack and - since I am a beginner - I have some doubts about the right signal path.
My VCO is the Make Noise DPO and it does not have a gate-trigger in.
How can I control the gate? Currently - as shown in the pic - I am sending the gate from the sequencer to the Maths and from the Maths I go into the CV of the VCA.
Another question: where is the best place to insert the filter?
Thanks in advance!
looks right to me
sound source -> signal in of vca, envelope -> cv in of vca, vca out to monitors (or wherever - mixere, processing etc)
nb I use signal in because vcas can also be used for cv and not just audio - modulate your modulation
a filter can go before or after the vca... whichever way sounds best for you in the current patch...
this is generally the concept of modular... generate a signal, do something to it, send it somewhere - try not to mix cv into the audio path (it's possible to damage speakers), apply modulation to things
see my signature for hints on how to get the most versatility in patching for the least expense
Hi, thanks for the info!
wishbonebrewery
If you are using a filter when its self-oscilating the VCA is best after the Filter so you can shut off the notes.
Thanks, I will try it!
