Thread: Opinions on starting rack build
				Maybe the design has changed. But I see 7U worth of rack. Are you placing this in an Intellijel case? If so, go for the 104HP. It has main outs and MIDI built in... but you won't be needing an Intellijel MIDI 1U module with the Expert Sleepers FH2.
You can ditch the 1U pedal send/return as it needs another module to function. I don't see it in your rack.
You can replace the Intellijel MIDI module with an Intellijel headphone jack.
Ditch the Mutable Instruments stuff and replace them with micro versions of each. You'll appreciate the savings in rack space more than you realize.
