Ideally, with those 4ms pods, could a mismatch in depth be highlighted?
-- liquid_air
Unfortunately the data here cannot be fully trusted. I run into such an issue where the depth info both in MG and in the manufacturer's manual is not true, which made me purchase a module which ought to fit in a Pod but didn't. 2hp Rnd v1 still has depth set as 34mm last time I checked and I had to reach out to manufacturer for a change. Real depth is 45mm with power cable, 40mm without. Both are too deep for a Pod and I have no idea why they don't state the real depth.
-- ParanormalPatroler I know! I bought a 2hp NSE and it's deeper then stated and wont fit in a Pod.
Also 4ms seems to have over stated the Pod depth at 34.1mm, from my measurements 32mm and under will fit, under 33mm might fit, and over 33mm probably wont fit. Maybe their prototypes and/or manufacturing proofs were 34.1mm deep but the production copies ended up a little shallower?
