Thread: Transitional helper rack
				Thanks for the feedback! I was peripherally aware of the MScale. I've tuned by ear the few times I've wanted a harmonic relationship between the GM and Cursus Iteritas, but a precision bias could indeed be helpful down the road. In the meantime, you reminded me to check: there's a global setting to enable the GM to output 0v - +10v. Done.
Yeah, the EMW double adder seems like it'll have a good lifetime as a general utility, so I didn't feel bad about spending $66 on it.
Next steps that I'm considering:
- an inexpensive noise source (it's annoying to isolate the GM's noise source and use it elsewhere),
- an envelope/modulation source. I thought a Low-pass Gate might be a good thing to trigger, but tonight I'm a little obsessed with the possibilities opened up by the Malekko AD/LFO,
- Expert Sleepers Disting as a "sampler plate" of more exotic functions, and
- an inexpensive sequencer as a general control/dynamic modulation source.
I'm trying not to overthink the sequencer. At first I thought the Korg SQ-1 would be fine, but then the Arturia Beatstep Pro looks so much more capable for the money.
Already arriving:
- patch cables. My patches are already limited by the number of physical connections I can make.
