i have the sv-01 and a-118, the maths and reverb are extras i would eventually like to get
yes this is my first time using modular grid (well first week), how could you tell!
this is what the user manual for the AS0084 says re-power supply:
"Power input:
12-15V AC external power supply 500mA or higher, 2.1mm DC socket.
230v mains adaptor only supplied for Euro models. 115V US adaptors are available from Noisebug.
Width:
84HP
Introduction
This is a lower cost alternative to the pricey aluminium
style cases.
The AS0084 will take any combination of Concussor,
A100 or Integrator modules with no problems of gaps or
lining up because it does not use tapped strips.
Power Supply
The power supply board has 9 Doepfer style connectors
and 3 Integrator sockets. A 5V power rail is
provided for those modules that require it. It uses an external power supply of 15VAC. This case uses 15V AC (NOT
DC!) Use a minimum of 500mA external power supply (not supplied). We can only supply 230V external adaptors with
either UK or Euro plugs.
As the power supply requires AC, it does not matter which way round you fit the connector. If you accidentally use
a 15V DC power supply, it will not cause any damage, but the system won’t work.
The case will generally supply a full set of modules unless there are too many power hungry modules."
