You can just use the Behringer sequencer and Pam's for clocked and/or stepped modulation. Throw in a slew generator or two and it gives you a pretty handy way to design modulation. Some cheap logic modules or switches (or a Tesseract Selecta, which has both) will allow you to combine and move through all these gates/triggers/divided clocks in interesting ways, so you can have complex sequence of gate or triggers from the BSP and a simple clock divided counterpoint from the A-160 set up and then switch between having one, the other, both, or neither. It even works on envelopes and other modulation that is positive voltage, so you could do some of the same with the Fuji.
You could also just sell them. Whichever works.
