What do you use the most? You should build your live setup around a condensed version whatever it is you do naturally. What's a patch you've done recently that you felt you were able to jam on productively for a while? This might be more of a songwriting challenge than a setup issue.
How do you normally sequence this stuff? Do you plan to have distinct melodies/structures that evolve, or do you usually make your music by just improvising and not worrying about what "song" you're playing? I don't see a dedicated sequencing device on here, and that might streamline this process for you. There are a lot of possibilities in here for sequencing a set like you've described, but as you say, this potential is scattered across various modules without a clearly emerging singular logic. That aspect is extremely personal and will benefit greatly from trial and error that I presume has already started.
Since you know you want acid stuff, start with whatever makes the best and/or largest amount of usable acid sounds for you and go from there. What's your favorite way to put that element in, and how would you generate the pitch and gate info for it?
