The A-118-2v will save you 4hp over using the A-119, but wiggler's right, the Chaos will give you much of the same randomitry.
Get a couple Rides in the Storm QAM active multiples instead and share those CVs.
Stereo vs. mono. You'll either have to mix in stereo, run long wires, combine two channels, or throw one side away.
What's your usual clock going to be? Several modules here give or require a clock.
Can you distribute the clock(s) to where it's needed?
Are you hoping to use stacked cables? Don't do that.
noodlehut.bandcamp.com
