I agree, definitely onto something there. One note, Quadrax self-attenuates.
2 Hp trim may not be the attenuation you want. Something a little bit more like a 3xMIA could fit into this setup and add additional fleixbility with mixing, inverting, as well as attenuation.
You're def looking in the right directions, though, this would be a versatile setup for the money.
Also, uPlaits, uClouds, and uRings are available that take up less space, in case you wanted to sacrifice a bit of ergonomic value in exchange for HP.
Best wishes and luck!! :)
― Friedrich Nietzsche
