I quite liked the look and form factor of a double rackbrute 6U
Hadn't thougt that power would be an issue tho.
Guess anyone could have made that mistake starting out
it's a common issue - often found when a power supply starts failing...
For now i took out the chainsaw so i can still explore
I will be investigating a self build case tho.
My current studiodesk (also self built) needs replacing so .... i want cook up a new design with integrated rackspace.
Preferrably adjustable in hight as well.
@JimHowell
About those befaco excalibus power supplies?
What are their power rating and would any old weller soldering iron suffice to build it?
-- Chrissozz
I think they're 1.2A on both the +ve and -ve 12v rails - this should be sufficient for 2 rows, depending on the modules - I have a good distribution of digital (mostly mutable), analog and passive modules and can in most of my cases run 3 rows of up to 104hp from one easily - under 80% utilization - out of the 3 9u and 2 6u cases I run with them iirc only 1 needs a bit of help (a frequency central power supply for a few modules)
most of mine were built with a 25€ soldering iron - only the latest one was built with ny hakko - just be aware they're really time consuming (26 headers with 16 pins each)
