There is also the ADDAC System 102 VC Radio. You can both scan and search manually or by voltage control. Everything on the module is under voltage control. Not only does it scan stations, it can search all of the glitchy sounds and fuzz in between as a noise source. ADDAC modules are very good quality.
 Sweelinck and EuroBadger
