is this for home/studio or performance?
if for home/studio I'd definitely consider 12u/104hp... and I'd fill the extra 104hp with utilities... this will exponentially increase patching possibilities... and I'd really look at 6u vertical-ish and 6u horizontal-ish - not perfctly - as you'll want a greater than 90 degree angle - so cables will fit...
tbh I'd also consider for live... as you'll be able to add matrix mixers and switches and other control modules... in the closest row...
