Hi Cédric,
Thanks a lot for your help. I was expecting it to be this.
When you say "You have to pass it thru an enveloppe + VCA combo", could you detail the actual connection?
Should I just output the sub OUT to an EG (I have a pip slope mk2 at the moment) through its gate or trigger?
And then to the VCA?
Thank you very much for the help, much appreciated.
Had a glance at your 416 rack and there is a lot of the same I am looking at (Voltage Block for instance).
Best,
Olivier
