Hi and thanks a lot for the hint, really appreciated.
I am using a Torso T-1 to sequence this module and I know I have the option to send cv with pitch OR velocity but I cannot get my head around as to how send various levels of velocity (I can do that on T-1 no problem with as it has a dedicated knob for this function).
When you say "you will need a sequential that has a velocity parameter" it refers to that?
Now, "modulate the trigger before entering into the SY0.5" in the trigger input or pitch?
Really sorry if my question seems stupid but as I said, I am only starting.
Thanks a lot to both of you.
Olivier
Hi,
I imagine that they refer to the Trigger input, I see that it responds to different levels of the trigger, so the higher the peak voltage of the trigger, the greater the response of the internal VCA.
Other modules respond the same to a 6V trigger as to a 8V trigger or a 10V trigger. In this case, it appears that the trigger directly drives an internal VCA, so it is sensitive to the trigger voltage.
To take advantage of this you will need a sequential that has a velocity parameter or modulate the trigger before entering into the SY0.5.
Best regards,
-- ferranadsr
