If you want to use effects pedals - you really want one (or more) pedal interface modules(s) - as euro level is way too high for a lot of them and the return will be way too low
dixie will massively benefit from a sub mixer
2hp modules can be extremely difficult to work due to ergonomics
everything (as usual) points to a bigger case!!!
Re: 2hp ergonomics. I'm a guitarist... have long, thin, agile fingers, but thanks for the heads up. :p
Sub-mixer need noted.
I'm not sure I'm going to use the pedal boards or not at this point. I may be using them concurrently (twiddling knobs with a guitar/bass on the shoulder). I will wait to see how this all fits into my work flow. Right now, I'm leaning towards using guitar FXs in line and going through the A-119.
Not the same, I know, which is why I again ask, which effects are most crucial in your opinion(s)? Delay? Reverb? Something else?
Thanks and appreciation! :)
― Friedrich Nietzsche
