A sequential switch is used, for example, to channel the modulation signal from a source to several destinations dynamically by means of a trigger. You can also send a sequenced trigger to different destinations.
-- ferranadsr
Interesting, that's something I use stages for. I guess I was conflating it with sequencing.
So, would ornament and crime or a pams be more utilitarian? I know that o_C has a lot of different algorithms, and can have two operating at the same time, but I also feel like pams has more direct programming.
