How would you define a sequential switch as opposed to a sequencer?
I will often use stages as cv sequencers
-- fretless19
Hi,
A sequential switch is used, for example, to channel the modulation signal from a source to several destinations dynamically by means of a trigger. You can also send a sequenced trigger to different destinations.
It is a basic module, for example
https://www.modulargrid.net/e/doepfer-a-151
You can watch this video where they explain it very clearly with a lot of options.
BR
