@wiggler55550: thanks for the interest
offsets simply are “fixed” control voltages, we deal with them all time long within modular synthesis. For instance, you set the pitch knob of an oscillator to 12 'oclock, you don't move it anymore: you just set an offset; then you might want to control the pitch, of the notes the VCO will play, by means of a keyboard or capacitance plates (probably similar to the ones of this Cells module), so you will send a different offset to the VCO each time you play a different note of the keyboard.
I try to explain my need.
I will purchase Intellijel uScale II, it features a Shift Input which accept voltages in order to obtain 3 functions: (a) to navigate among the pre-stored scales, (b) to shift the interval note, (c) to shift the tonal note. Adopting fluctuating voltages (any cv source controllable by the means of a pot) I couldn't skip values and go immediately & exactly to the desired scale, interval, tonal note. Hence, pre-stored offsets are essentials to this kind of application.
It seems this module might make the grade: to store voltages (offsets) and to recall them by the means of capacitance plates, Sequencer might be engaged as well, though not necessarily. My only doubt concerns the HP width of this module, referring to my need, otherwise it is cool wide.
Sorry, I didn't even notice there's a video, I will watch it, thanks.
Best
