Enough force can bend or snap a 3.5mm plug, but 1/4" plugs are far more substantial. And accidents like that DO happen!
especially when the modular lives on the floor - I managed to accidentally kick a stackcable sticking out of a module - bending it into unusability...
FYI, don't go smaller than a Mantis if you've not bought a case yet. I've seen dozens of Rackbrutes, Palettes, et al get jammed out with "sexy" modules, resulting in...well, nothing in quite a few instances because the "utility modules" were totally ignored. The smaller cases (below 2 x 84) are far better suited for what I call "mission specific" builds instead of generalized builds resulting in a full-on modular. Small cases (without some good discipline on the part of the user) also result in potential fails such as teensy controls that have to be adjusted with tweezers because your fingers DO NOT fit. They also tend to be builds in which essential modules get left out; this is particularly awful when someone opts to jump into modular without advice, buys everything, and then wonders why their "modular synthesizer" doesn't work and/or sounds like refried garbage. Basically, it's pretty simple to put together a good basic build just by skimming the forums here, or hanging out on The Site Formerly Known As Gearslutz or The Site Formerly Known As Muff Wiggler and observing the "traffic". But it's EQUALLY easy to spend thousands on a compromised pile of crap, especially when not paying attention to all of that advice.
completely agree with this...
In fact, some of the best base-level info to remember can be found in Jim's sigfile above.
I'm going to quote you on that...
I have the same in my Modwiggler signature - and it's inspired at least one other forum member to adopt similar statements in their signature file...
