Looking for a simple headphone output for my eurorack which I can also use as an audio output to my audio interface (Steinberg UR22C)
I've narrowed it down to the ALM HPO and the Joranalogue Transmit 2
Second hand I can get the HPO for £70 ($82) less than the Transmit 2
Would welcome advice on which one to get
I'm starting out and will principally be using it for headphones
Thanks!
-- MrMojoRisin
The HPO is the no-nonsense solution in a small rack and does a decent job for me.
More often I am using the Erica Pico OUT since I usually do monitoring on a set of 3.5 mm jack  earphones and record on a pocket recorder at the same time.  It's my go to for that scenario so I have one in all of my small cases.
