how are you interfacing with your computer? and/or mixing the semi and the rack?
you definitely don't need so many buffered mults - passives will do
no filter?
no waveshaper?
it's a bit pedestrian...
I'd get a better effects module - which can take more modulation and better ergonomics - fx aid xl or bigger!
standard advice: get a bigger rack you'll need it sooner than you think... tiptop mantis is the best bang for buck (hp/price/manufacturer reputation/good power!)
wait a moment , this configuration is work in progress. i use niftycase to interfacing with daw but actually i'm using the rack only like a companion of behringer crave. i don't have each modules showed in configuration. i use the modulargrid like "bom" ;)
