TL/DR: Man seeks to mangle audio from DAW and create quirky loops with DFAM. Did he do this right?
-- rckitup
Yes...and no. And the "no" part has to do with having the DFAM in your cab, filling up 60 rather spendy HP. You should take that out, put it back in ITS case and on ITS power, and leave the cab for things that have neither. As for the "yes"...it's sort of conditional on that DFAM's presence as well. Thus far, the module choices are OK, but there's quite a bit missing which also requires putting the DFAM back where it belongs. There's things that could be done better here, but if you don't have room for the modules that would need, you're sort of stuck.
Okay but what would I be missing? I guess you mean the 3 Envelopes the Dfam can put out? Im interested.
i did rework the whole case tho, ill probably post a more focused question soon, theres a couple of things im getting stuck on.
