Thanks so much for the replies. I really like that TipTop case, although it looks like its sold out everywhere. There look to be a few on Reverb though.
if you can wait new ones turn up in stores from time to time - including a run of black ones due in a few months or so
Lots of research to do on these suggestions. I had not considered floor/expression options or an isolator but both make perfect sense. That Minimix seems cool with the panning options as well... never enough VCA's, right? Great stuff. I'm sure I will have more questions as I research.
yeah not things you think about until someone points them out... more vcas are good... as are more questions!!
I didn't mention in the first post, but I've done quite a bit of DIY building, pedals and amps. I know this is an option in eurorack, and I'm navigating options for retailers. I'm more of a "full kit" than a source parts guy. Seems like Thonk and Synthcube are the big players, Modular Addict... Are there any modules you would recommend staying away from as kits? Pedal kits sometimes get you 90-95% of the way there, but there will be a difference in the sound of an official vs clone. Is this the same in modular? Is this opening a can?
-- cdc3jj
no idea how close the DIY stuff gets to factory built modules, I suspect it's 100% - but then, a lot of the DIY modules are DIY only so it's difficult to compare - so I've never compared any DIY kits I've built to factory built modules - but I have built quite a few... tbh - kits don't save that much money - so if there's a factory built model then I'd tend to buy that, unless you really like building kits - if you want to save money sourcing your own components is the only real way to save money... and then only if you buy for quite a few modules at once and round up for price breaks and free postage and then you spend a lot of time doing all the searching and substituting components
what I have compared is a few MI builds - specifically Veils mk1 and Shades mk1 - mine are close but I think that's down to my smd soldering skills and possibly to some extent part substituting skills (it's been a while - might not have paid attention to capacitor types as much as I should have) and not the BOM or pcbs - all MI modules are open source...
